44 Users Online (43 Members):
Forums >> Revit Building >> Technical Support >> Wall type transition
I have two wall types that need to make a specific transition. One has a finish face of cmu and the other has insulated metal panel. I need the the cmu finish to wrap back into the structure and have the insulated metal panel abutt up to it. Attached is an image of the condition I'm working with. The halftone linework is the imported condition I'm trying to duplicate. Thanks! crw
Turn off the wall join at the end of the masonry wall and edit the type setting the masonry to wrap at wall end.
That's what I thought too. The wall type in the previous image was set to wrap at the ends and the wall join was off. Alternatively, with the wall joins on the structure cleans up but the other layers don't wrap the way I'm trying to.
Nevermind I figured it out. It was simply a matter of inserting a mass with the desired material and then joining the geometry.
How to create a coved/ radiused corner at Floor-to-Wall Wall-to-Ceiling |
Tue, Apr 15, 2008 at 8:40:05 AM
How to Hide Door Transition Strip with Materials Finishes in RCP (Revit 09) |
Thu, Sep 4, 2008 at 4:13:16 PM
Wall Thickness in Type Parameter |
Fri, Jun 1, 2018 at 7:39:15 AM
Transition to Revit from Autocad |
Sun, Mar 24, 2019 at 8:44:22 AM
stair railing transition at landing issue (2015) |
Wed, Sep 16, 2015 at 9:29:50 AM
Members: | 2017222 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
