136 Users Online (135 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> slanted wall in elevation
Mon, Oct 24, 2005 at 12:58:57 PM | slanted wall in elevation
gigils
how do i draw a wall at a slant in elevation? (ie not 90 degrees level-level)
Mon, Oct 24, 2005 at 2:05:13 PM | RE: slanted wall in elevation
Rythmick
5 Stars: 2 Votes
Use "Create" - "Wall" to make an in place family using "Solid Blend" - offset the top sketch from the bottom sketch.
Mon, Oct 24, 2005 at 6:26:43 PM | RE: slanted wall in elevation
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Create a mass that gives you the surface you require, then use wall by face (providing your are using 8.1) This way you can still have layers to your wall.
Wed, Feb 8, 2006 at 9:14:12 AM | RE: slanted wall in elevation
gigils
thank you for your tips!
Wed, May 26, 2010 at 7:48:33 AM | slanted wall in elevation
westminster30
mr. spot --
 If I'm using Revit 2010, do I create a Mass In-place, or create one from the template?  Because I tried creating a mass on plan (just playing around with it) and it didn't work.  It came out as a flat object with no height.
 Forgive me, I'm not very good with the mass-modeling.
 W
Wed, May 26, 2010 at 7:58:48 AM | slanted wall in elevation
westminster30
So, I've managed to model a wall under COMPONENTS (HOME) and by MODELING IN PLACE.
Is there a way I can give this wall the same properties (like structural usage) as my other walls, and can I assign a Wall Type to it?
Thanks!
Wed, May 26, 2010 at 8:05:38 AM | slanted wall in elevation
Mr. Spot gave you the options in his earlier post.  If you want full wall properties then use the mass to create a face then use wall by face using one of your wall types.... Then you can get rid of the mass or hide it someway so that you can modify later.
Curtain Wall in a Slanted Wall?
Wed, Aug 8, 2012 at 9:17:57 AM
Slanted curtain wall help! (pic attached)
Wed, Oct 22, 2014 at 6:02:40 PM
opening in slanted curved wall
Mon, Sep 29, 2008 at 10:32:58 AM
section in slanted wall
Mon, Mar 4, 2013 at 3:12:21 AM
How to make a slanted curtain wall?
Thu, Apr 24, 2014 at 3:35:16 AM
Page generation time: 0.8783
