58 Users Online (57 Members):
Forums >> Revit Building >> Technical Support >> Room tag callout says room "not enclosed"
1 Posts No Rating |
these rooms where tagged before... I needed to re-design and move the rooms around and I moved the tags with there boxed areas out to the side. Now when I wanted to re-bring them into position a warning note says "Room is not in a properly enclosed region" I erased them all and try re-tagging, no luck. I closed the drawing and re-opened...stricke two... any suggestions? Edited on: Sun, Oct 24, 2010 at 10:00:34 AM
Edited on: Sun, Oct 24, 2010 at 10:33:38 AM
Several things to consider: - Rooms can be created without bounding elements but when that happens, you get your error message.
- Rooms must exist and be on in order to be tagged
- If you delete a room, the room definition still exists. To delte this, create a schedule and delete this room definition there.
- If rooms exist, but you don't know where they are, you have a few options.
- Delete the room from the room schedule
- In the schedule, hover over the room and select show
- in a plan, select tag all using the room tag
Room tag not showing in only one room. |
Fri, Oct 1, 2021 at 11:04:59 AM
"TO ROOM / FROM ROOM" DOOR SCHEDULE DISCREPANCY |
Wed, Nov 9, 2011 at 5:35:20 PM
Room tag problems |
Sun, Aug 24, 2008 at 12:19:37 AM
Help. I forgot how I "turned off" the room tags. |
Tue, Oct 8, 2013 at 7:18:18 AM
11
Using Room Tag Family Parameters in a Celing Tag Family |
Mon, Sep 22, 2008 at 7:52:40 AM
Members: | 2017200 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
