39 Users Online (38 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> HOW do I find new family elements once I've loaded them into my file?
Sat, Oct 23, 2010 at 6:04:30 AM | HOW do I find new family elements once I've loaded them into my file?
CRB14
I've been creating very simple wall mount shapes (20mm circular spheres etc) and when I load it into my main file, I click on the cornice I want it to attach to and I can't seem to locate it thereafter. Its a tiny thing, and I have tried different section views, 3D views etc and can't seem to find it.....any ideas? I'm basically adding a mass detail to a cornice and want to create an array once I've positioned it on the already positioned cornice.....
 Hope this makes sense, I would appreciate any and all ideas of what I'm doing wrong- am a newbie to so step by step instructions would be ideal.....thanks!
Sat, Oct 23, 2010 at 9:35:27 AM | HOW do I find new family elements once I've loaded them into my file?
3.5 Stars: 395 Votes
Did you create a profile family to use as a wall sweep?  If so, then did you set the intended use in the family under categories and parameters?
To use a wall sweep, roof or floor edge sweep, you have to start that command then create a new type and set which profile you will be using in the type settings.  If you have set the use in the family, it will show up in the pull-down when you click on the profile to use.
[Revit Structure 2009] Create 'Type Catalog' of existing family-types
Wed, Apr 1, 2009 at 9:18:17 AM
'unable to copy elements from file' error in inserting a saved view
Wed, Jul 25, 2012 at 10:16:55 AM
How should links be loaded into a main model file? <Noob question>
Fri, Dec 9, 2011 at 8:42:52 AM
Receiving "Can't keep elements joined" message when joining 3 family elements
Tue, Apr 21, 2015 at 11:26:44 AM
How to find what view a loaded family is in...?
Tue, Aug 14, 2012 at 9:42:13 AM
Page generation time: 1.4403
