60 Users Online (59 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Floor Help
Sat, Oct 23, 2010 at 2:12:12 AM | Floor Help
DERRICK88ROSE
I am using Revit Arch 2011 and I am having an annoying problem at the moment.  I am trying to add a material to my floor.  i separated the floors by drawing them individually for each room to avoid the material being added to all rooms. Well, when i tried to apply it,  it completely adds the same material to all my floors on that level.   If someone could please explain why I am having this problem it would be much appreciated.
Sat, Oct 23, 2010 at 5:44:08 AM | Floor Help
4 Stars: 201 Votes
"when i tried to apply it,  it completely adds the same material to all my floors on that level" - Because you have the same "Name" (same floor) in every room,in one room select the floor go to properties and rename the floo, then do the same to the others (i.e. room1, room2.....)
Sat, Oct 23, 2010 at 9:49:10 AM | Floor Help
3.5 Stars: 395 Votes
I think you will find out that the individual floors may not have been a good idea but... typhoon has given you the correct answer for doing this.
In the future, you may think about another method.  First, think about modeling as you would build it.  The floor really has two components.  First is the structure.  You should model this at least as one floor throughout, just as you would build it.  If you want to add a finish to it, you could ... probably assign what you would use in most areas.  Then if you needed different finishes in some areas for rendering purposes, you have two options:
  1. You can split the face of the floor and assign a different finish material to that area.
  2. Or you could add a thin floor that is just the finish material.  If you do this, this material needs to be "proud" of the floor below it.  (Sometimes it may be advisable to do this for the entire project and the floor structure would not include any finish, just sub-floor structure.    BTW - All of the floors you have already could be this.  Just change the thickness of all of them accordingly and add a new structural floor below them for your total project.)
Sat, Oct 23, 2010 at 1:43:48 PM | Floor Help
DERRICK88ROSE
Thanks you guys.  These two options really will help me out.  I will try to reapply the floor as a whole, then split it up into the sections I want for my finishes.
Also, does this apply for the walls to?  Can i split them to add different materials?
Sat, Oct 23, 2010 at 2:30:16 PM | Floor Help
4 Stars: 201 Votes
"Also, does this apply for the walls to?  Can i split them to add different materials? " -YES
Sat, Oct 23, 2010 at 9:07:02 PM | Floor Help
DERRICK88ROSE
Alright. Thank You!
Ground Floor info. appearing on Second Floor
Thu, Jun 9, 2016 at 2:24:40 PM
floor sketching
Tue, Aug 26, 2008 at 3:35:49 PM
(Dumb question) Can't see first floor when in second floor view [Revit 2015]
Thu, Jul 16, 2015 at 6:11:13 PM
First floor slab or ground floor ceiling?
Fri, Aug 30, 2013 at 7:41:03 AM
RAC 2010 Structural Floor V Floor - Whats the difference
Tue, Jul 27, 2010 at 8:35:33 AM
Page generation time: 0.4685
