97 Users Online (95 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Drafting View Catalog with View Names
Fri, Oct 22, 2010 at 11:12:24 AM | Drafting View Catalog with View Names
jamiew
Revit Architecture 2009
We have over 1000 2D Drafting views that have been saved out from various projects to an rvt file.  I want to print out all views and begin to organize them so that we have a detail library.  The problem is, if I print all the views on 8.5x11 sheets, I have no way of knowing what the name of each view is.  Is there a way to automatically label each view?
The only thing I can think of is creating a giant sheet so that each view has a title, and window plotting 1000 times.
Thanks!
Autodesk Revit MEP 2015
Fri, Oct 22, 2010 at 4:18:52 PM | Drafting View Catalog with View Names
Why don't you place all these views in one file then place tose on sheets, label and print from there.
Actually - don't kill another tree !  Once in the file, organized by category, with multiples placed on a sheets and titled, these views are easier to find, look at and import into a project.
At least that is what we have discovered.
This user is online
Thu, Nov 18, 2010 at 9:53:27 AM | Drafting View Catalog with View Names
jamiew
I found a 2 step workaround. But you need Bluebeam software, although this might work for Adobe Acrobat as well.
I ended up plotting to pdf (we use bluebeam) and creating an individual pdf file for each view.  Revit will then name each plot according to it's view name - if not on a sheet.  Then, using Bluebeam PDF, I can batch plot these with a header or footer that shows the filename - which was the view name when it was in Revit.
Thanks WWHub for your input.
Thu, May 9, 2013 at 7:22:14 PM | Drafting View Catalog with View Names
structengg
where you able to print the title on sheet attribute as well? how did you do that? i have revu extreme
referenced sections
Wed, Apr 2, 2008 at 1:06:06 PM
Flagging new Drafting Views - How to reference a drafting view detail?
Wed, Aug 1, 2007 at 10:26:30 AM
Trouble copying detail items from Section View to Drafting View
Mon, Aug 19, 2013 at 1:08:06 PM
Using a callout on a drafting view
Fri, May 16, 2008 at 10:39:59 AM
Problem with importing drafting views from file ....
Fri, Oct 1, 2010 at 8:37:19 AM
Page generation time: 2.2267
