37 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Will the reset the Survey point affect consultant links?
Fri, Oct 22, 2010 at 10:26:14 AM | Will the reset the Survey point affect consultant links?
xixiha
Our situation here is
We didn't set up the survey point at the beginning of the project, now we want to set it right. The project base point will stay where it was before, but we are worring this adjustment will affect our consultants when they reload our updated model? Will it?
Or it depends on how they linked our model in at the beginning? My guess is if they linked it in as origin to origin, and never require coordinate from our model, it should be fine. But if they linked in as shared coordinate, or they required coordinate before, it's troubled. Am I right?
And also want make sure one thing, when we require or publish a shared coordinate, we actually match the the origin of the shared coordinate between the host file and the guest link file. right?
Project base point/ Survey Point
Tue, Nov 13, 2012 at 3:35:37 PM
Survey CAD file with large coordinates
Wed, Sep 21, 2016 at 10:36:26 AM
help - Toposurface & model
Tue, Feb 17, 2004 at 9:08:33 PM
What is the correct workflow for Referencing drawing to Survey point??
Wed, Apr 29, 2015 at 7:10:52 AM
Topography Elevation from Project Base and Survey Point is Incorrect
Thu, Jan 29, 2015 at 10:32:25 PM
Page generation time: 0.5015
