83 Users Online (82 Members):
Forums >> Revit Building >> Technical Support >> Rendering image files
where can you select custom textures (from .jpg files) into the rend appearance dialog? i cant find anywhere to drop them in in r2011
Its not very obvious where to select the new image files. When you're in the render appearance dialog with an existing material you want to change, click on the sample of the image and a new window will open. Then click on the image "source" link and a file browser will open to select a new image file. hope that helps
thanks - i wouldn't have found that... couldnt find it in the docuementation either!
Looking for rendering image files for brick |
Fri, Nov 6, 2009 at 10:01:41 AM
Image Files or Bitmaps |
Fri, Apr 23, 2010 at 5:03:30 AM
When Rendering, background image get realy bad |
Sat, Nov 11, 2006 at 11:54:44 AM
REA 2009 Background Image when rendering |
Mon, Nov 17, 2008 at 8:50:49 AM
Capture Rendering/Export Image |
Wed, Aug 15, 2007 at 10:34:26 AM
Members: | 2057574 | Objects: | 23076 | Forum Posts: | 152250 | Job Listings: | 3 |
