112 Users Online (112 Members):
Forums >> Revit Building >> Technical Support >> REVIT 2011 TO PDF FROM CUTE PDF PROBLEM...BLACK BORDER AROUND??
4 Posts No Rating |
Hi Whenever I print a document from revit to pdf through cute pdf writer then it shows black border on each side of sheet...I print on zoom to 100% and on a1 size....below is attached sheet...can anybody help??
Student version, right?
We use cute and we don't have that problem. 100% centered Take a look at your titleblock family.
It is because it is a student version. If you print to an oversided PDF then when you go to print to paper just shrink it down to the correct size. You in essence just have to print it twice to remove the black borders.
62 Posts No Rating |
If you take the drawing into Illustractor(Adobe) you can delete the black blocks and the text under them and then just save back to PDF, double check though sometimes the scale changes.
I don't want to be interesting. I want to be good. |
4 Posts No Rating |
YES IT IS A STUDENT VERSION....BUT I DIN'T GET WAT IS OVERSIDED PDF AND HOW TO PRINT IT TWICE TO PRINT IT CORRECTLY!
Ok, what I mean by printing it oversized is if you have your sheet set up as an 8.5x11, print it as 17x22 so the black is away from your paper space on the PDF. Then take the 17x22 PDF that has black on the edges and print it to an 8.5x11 which will crop it back down to the correct size and rid the black boarder. You could also do as wheelergc suggested.
1 Posts No Rating |
I have the same problem w/ the student version. With Adobe PDF Uder Tools, select "Advanced Editing" then "Touch Up Object Tool" Click on black box then delete and then you'll have to repeat the process again. Takes black boxes away. Also if you print from AutoDesk Design Review, doesn't print w/ boxes. I am having a problem though with it printing to the correct scale. It's off just a bit...either too big or too small.
Cute PDF not working |
Wed, Feb 8, 2012 at 3:31:23 PM
batch pdf's |
Sun, Aug 21, 2011 at 2:00:55 PM
Black lines printing grayscale in PDF |
Fri, Oct 10, 2014 at 4:46:46 PM
PDF print, no window border |
Thu, Jan 30, 2014 at 10:57:00 AM
multi pdf printing problem |
Thu, Apr 17, 2008 at 9:13:22 AM
Members: | 2056308 | Objects: | 23069 | Forum Posts: | 152315 | Job Listings: | 3 |
