121 Users Online (120 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Linked models, true north and publishing co-ordinates
Thu, Oct 21, 2010 at 11:18:55 AM | Linked models, true north and publishing co-ordinates
archie456
3 Stars: 1 Votes
Hi,
Quick question.
I have a site model which I Revit link in three buildings, I move them into place and publish the positions to their files.
I know this has worked because if I unload them, and then relink them to Shared Co-ordinates they fall into the correct position.
But when I open the individual building file, and select orientation there is no change between true north and project north eventhough they were rotated in the site model.
Does publish co-ordinates to a building model affecct true north (am I missing a setting or something??)
Thanks.
Thu, Oct 21, 2010 at 11:20:53 AM | Linked models, true north and publishing co-ordinates
archie456
3 Stars: 1 Votes
Ok, I've managed to answer my own post!
I need to click on Manage - Location for the building model to use the shared co-ordates! And then true north works!
True North vs Project North Linked dwgs
Thu, Mar 10, 2016 at 10:02:26 AM
Project North doesn't rotate back after changed to True North
Fri, May 7, 2010 at 3:24:14 AM
True north help
Tue, Jul 21, 2015 at 3:52:04 PM
Rotate true north
Wed, Jan 24, 2018 at 4:20:59 PM
rotate true north
Wed, May 21, 2008 at 9:21:13 AM
Page generation time: 0.4309
