39 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Copy Monitor Shaft Openings
Thu, Oct 21, 2010 at 10:48:30 AM | Copy Monitor Shaft Openings
mark7321
I'm new to revit structure and I copy monitored a floor slab from an architect's model. Before I did that I clicked on the options icon and went to the floors tab and made sure that the Copy openings/Inserts box was checked. After I copied the floor the openings are not showing up. I went into Visibility Graphics and turned off everything except floor and shaft openings in my model. The shaft openings are still not showing up. Do the openings not get copied and you need to cut them yourself?
Thu, Oct 21, 2010 at 11:16:39 AM | Copy Monitor Shaft Openings
I don't like shaft openings because I have other problems with them so I manually sketch the opening in the floor.
I tested this in a test project and the floor with shaft opening was there.  Something else going on.  Did you add the shaft after the floor was copy monitored?
Thu, Oct 21, 2010 at 8:16:15 PM | Copy Monitor Shaft Openings
mark7321
I deleted the previous slab that was copy/monitored because there were so many openings that the architect changed. This new floor that the openings are not showing up on would be brand new my project.
Copy Monitor Floors with Openings
Fri, Mar 28, 2014 at 11:56:56 AM
Copy - Monitor - Openings
Wed, Jul 23, 2008 at 12:23:28 PM
Copy/Monitor Shafts
Tue, Jan 12, 2010 at 1:49:22 PM
Copy/Monitor Openings
Tue, Aug 9, 2016 at 3:41:47 PM
A Floor That Can't Be Penetrated by Shaft Opening
Thu, Feb 20, 2014 at 2:30:49 PM
Page generation time: 0.3225
