61 Users Online (59 Members):
Forums >> Revit Structure >> Technical Support >> Design Option Issue - walls in 1 design option cutting thru a 2nd option
2 Posts No Rating |
I am working with design options on a project. I have the views set up to hide 1 design option and show the 2nd design option - however even though design option set 1 is not visible in the view, the geometry/walls from design option set 1 are cutting through the walls in the visible design option set; option set 2. So essentially, the set 1 walls are not visible, but creating voids in the walls of option set 2. I've tried cutting the geometry, using different wall joins, etc. Nothing seems to help the issue. Any ideas would be greatly appreciated! Thanks -
I use design options a lot and I don't see your problem ever. Are you sure you have these set up right? I wonder when you say "...I have the views set up to hide 1 design option and show the 2nd design option..." If the DO's are in the same option set, the view shows either option 1 or option 2 .... not a hide option.
2 Posts No Rating |
Sorry, I misworded my last post. I am not "hiding" the design option, I am using the settings in Visibility/Graphics to show one design option per Plan view. The Design Options are in different Option Sets. I tried to have multiple options in 1 Option Set, but when I did that, every option in that set showed in the view, dispite V/G settings. Maybe having the DO in different sets is the issue ...
Design Option view setting |
Fri, May 16, 2014 at 8:02:11 PM
DESIGN OPTION ISSUE????? |
Thu, Nov 5, 2009 at 9:54:25 AM
Design Options - black hole. |
Wed, Feb 14, 2007 at 12:54:40 PM
Cannot place room in Design Option |
Wed, Apr 18, 2012 at 4:41:43 PM
Design Option Sharing |
Mon, Dec 6, 2010 at 10:02:19 AM
12
Members: | 2042225 | Objects: | 23026 | Forum Posts: | 152216 | Job Listings: | 3 |
