Forums >> Revit Building >> Technical Support >> how can I make an arc setback in a revit wall, not openings.
85 Posts No Rating |
I want to make some setback in a revit wall , like a square shape or other shape setback in a wall but not doing an openings. I found reveals can do part of this, but if I want a circle shape setback in a wall , the reveals can't do this. look at my picture I want to make an arc setback.
沧海月明珠有泪 |
the ARC setback is labled like this place. this is a model in sketchup.
沧海月明珠有泪 |
- Goto an elevation view
- Set your workplane to be the face of that wall
- Create an in-place family - void extrusion
- name it
- Category wall
- Set it to cut the wall before finishing the family
sorry, I forgot to say that I want to make a recessive shape in a project file, not in a family, so I have make a mass in a wall, but I can not cut it in a wall, also I have made a viod but it too can't work in a project file. Is that no ways to produce an recessive shape in a wall in a project file?
沧海月明珠有泪 |
as I followed your step make a in family void wall, but it can't finish the shape. as the attachment show the revit errors. Some Void Forms of this family do not cut anything and will be deleted. To make a Void Form cut something else use the Cut Geometry tool.
沧海月明珠有泪 |
WWhub told you this: - Goto an elevation view
- name it
- Category wall
Did you do that? did you select the "CATEGORY: WALL" (not "MASS" ? After this, go to a 3D or plan view and check if the void is cutting the wall like you want, then use the "Cut geometry" tool, select the void then select the wall, now you can finish your "in-place" (system) family.
I have do the steps exactly as you have told me. 1. first I made a wall in a project file 2 go to elevations select a work plane 3 I select an in place family under category of wall 4 I make a void and place it in the wall 5 I finined the void 6 last I can't finished the whole molde why , is there somthing I have missed? the last step in the I have grasped as a picture shown below.
沧海月明珠有泪 |
where is the "Cut geometry" tool?
沧海月明珠有泪 |
thank you, I have omitted to use the cut geometry tool, so fulish I am. thanks a lot!
沧海月明珠有泪 |
how to make an arc reveal in a wall in revit? |
Fri, Oct 22, 2010 at 7:17:07 AM
Wall opening setback for door jamb |
Tue, Apr 30, 2013 at 8:43:07 AM
Wall Sweep Setback |
Wed, Dec 16, 2009 at 1:12:37 PM
Arc Walls with curved top? |
Thu, Aug 7, 2008 at 2:04:22 PM
Curved wall openings |
Fri, Oct 15, 2010 at 12:42:12 AM
Members: | 2099066 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
