115 Users Online (112 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Revit fill/surface patterns for 2011
Tue, Oct 19, 2010 at 11:01:24 AM | Revit fill/surface patterns for 2011
lawebb13
I am trying to find or create a fill/surface pattern that can be manipulated to create different tile finish patterns and off set grout lines on walls, that can also be aligned and adjusted in the elevations.  Please help.  Thanks.
Tue, Oct 19, 2010 at 11:04:06 AM | Revit fill/surface patterns for 2011
lawebb13
I have found some other messages on this subject referencing "hatchkit" where can I find it?
Tue, Oct 19, 2010 at 1:33:20 PM | Revit fill/surface patterns for 2011
4 Stars: 203 Votes
Here you have: http://www.hatchkit.com.au/
Surface Patterns in Perspective
Fri, Jan 27, 2012 at 7:04:34 AM
Model Fill Patterns
Tue, Jun 22, 2010 at 11:35:19 PM
Perpsective Fill Patterns
Mon, May 10, 2010 at 6:12:50 PM
Is there an easier way to create surface/fill paterns?
Fri, Dec 1, 2006 at 9:21:19 AM
Topographic surface Fill cut control
Fri, May 6, 2011 at 10:23:50 AM
Page generation time: 2.1826
