62 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Beginner Question with Scale on Viewport
Tue, Oct 19, 2010 at 9:55:17 AM | Beginner Question with Scale on Viewport
DMussell
Very new to Revit, so I need some help. When I place a drafting view on a sheet, it displays a title (which I want) but it also displays a scale (which I do not want) I just want it to say "vicinity map" but have no scale. I have duplicated the "viewport 1" and tried to change the properties, but can not find where to take off the scale. Thanks in advance.
Tue, Oct 19, 2010 at 11:07:39 AM | Beginner Question with Scale on Viewport
TKennedy
4 Stars: 7 Votes
You need to edit (or make a new family) the View Title family. You can edit the existing family so you can turn the scale label on and off with a parameter, or if you don't want to do that you can delete the scale label, save as a new family, then load the new family into the project.
Once that is done you can go back into the viewport properties and tell it which family/type to use.
Tue, Oct 19, 2010 at 2:49:53 PM | Beginner Question with Scale on Viewport
coreed
coreed Avatar
4 Stars: 16 Votes
watch this video. it is on a different subject, but  it does what you want to do.
http://www.screencast.com/users/NMcClure/folders/Revit%202010%20Tutorials/media/8382a723-25b3-4086-b199-3f52648da7ef
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
REVIT Building 9.1: viewport and scale on dwg sheet
Tue, Apr 17, 2007 at 4:34:28 PM
Metric Viewport in an Imperial Unist based project
Mon, Aug 11, 2008 at 9:16:59 AM
downsizing a viewport
Thu, Jul 8, 2010 at 7:03:44 AM
viewport title with line question
Tue, Jul 8, 2008 at 11:38:18 PM
Viewport larger then needed on sheet
Tue, Feb 20, 2007 at 10:38:26 AM
Page generation time: 0.9150
