37 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Family Type
Mon, Oct 18, 2010 at 11:31:42 AM | Family Type
nooneuknow
nooneuknow Avatar
I need to create an extruded family that can rotate in any direction. Is there a family type or an option button that I'm missing that will allow me to do this? It seems that everytime I create an extruded family I get the error, "Can't rotate element into this position" How do I get around this?
Mon, Oct 18, 2010 at 1:38:54 PM | Family Type
TKennedy
4 Stars: 7 Votes
The only way I have found to do that is making nested families that are work plane based, then hosting them on reference lines that can then be rotated.
Mon, Oct 18, 2010 at 1:45:52 PM | Family Type
Have you turned always vertical off in the family?
Mon, Oct 18, 2010 at 2:45:29 PM | Family Type
nooneuknow
nooneuknow Avatar
Yes, I turned "Always Vertical" off and "Work Plane Based" on. I'll try the nested family thing and maybe that'll work. Thanks.
Edited on: Mon, Oct 18, 2010 at 2:45:59 PM
Editing Family Type
Tue, Sep 21, 2010 at 3:58:32 PM
excluding a type in the family type parameter
Thu, Mar 20, 2008 at 3:38:33 AM
Create New Family Type for Drop Down Menu Family Parameter?
Wed, Nov 16, 2016 at 5:48:01 PM
adding parameters to a family with a type catalog
Thu, Feb 19, 2009 at 11:10:21 AM
Major issue in Family Default Type setting
Thu, Nov 23, 2017 at 8:48:10 AM
Page generation time: 1.0666
