Forums >> Workflow & Implementation >> API & Third Party Apps >> add in manager cannot load dll
Mon, Oct 18, 2010 at 2:42:19 AM | add in manager cannot load dll
Peerrapath
Hi, everyone
I'm a newbie on API development and I found a problem when try to use "Code Region 6-1: Getting selected element parameters" from Revit API developer guide example like this
 void GetElementParameterInformation(Document document, Element element)
// Format the prompt information string
String prompt = "Show parameters in selected Element:";
StringBuilder st = new StringBuilder();
// iterate element's parameters
foreach (Parameter para in element.Parameters)
st.AppendLine(GetParameterInformation(para, document));
// Give the user some information
MessageBox.Show(prompt, "Revit", MessageBoxButtons.OK);
String GetParameterInformation(Parameter para, Document document)
string defName = para.Definition.Name + @"\t";
// Use different method to get parameter data according to the storage type
switch (para.StorageType)
case StorageType.Double:
//covert the number into Metric
defName += " : " + para.AsValueString();
break;
case StorageType.ElementId:
//find out the name of the element
ElementId id = para.AsElementId();
if (id.Value >= 0)
defName += " : " + document.get_Element(ref id).Name;
else
defName += " : " + id.Value.ToString();
break;
case StorageType.Integer:
if (ParameterType.YesNo == para.Definition.ParameterType)
if (para.AsInteger() == 0)
defName += " : " + "False";
else
defName += " : " + "True";
else
defName += " : " + para.AsInteger().ToString();
break;
case StorageType.String:
defName += " : " + para.AsString();
break;
default:
defName = "Unexposed parameter.";
break;
return defName;
I've already add reference autodesk.revit and systems.windows.form also
Then I build solution and try to run for create dll file and use add in manager selected dll from that build.
But it show dialog "unable to load .dll"
I miss some command or function when I try to build that class library.
Can anyone help me, I would like to thank you.
Revit TotD – 7.30.09: Revit 2010 Add-In Manager
Thu, Jul 30, 2009 at 7:08:14 AM
install issue dll not recognized
Workflow & Implementation >> Chameleon
Mon, Dec 29, 2014 at 3:45:34 AM
Building system.dll error
Sun, Mar 13, 2005 at 12:32:31 PM
Average Pay for a BIM Manager
Thu, Apr 4, 2013 at 2:41:11 PM
LOADING REVIT
Wed, Oct 13, 2010 at 4:18:33 PM
Page generation time: 0.6381
