115 Users Online (114 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> cable system help
Sat, Oct 16, 2010 at 2:00:50 PM | cable system help
GUYERBS
Does anyone have any suggestions for making a cable system?  The look I'm trying to achieve is similar to a suspension bridge, but at a much smaller scale.  The system will be a back drop to a bar.  I'm assuming I should make a curtain wall system and then modify it to look like cables, but I'm not having much luck.  Any ideas are appreciated!
Sun, Oct 17, 2010 at 1:40:02 AM | cable system help
revittutorialsonline
you could use bracing, and select a circular beam and then just make the radius quite small
tom
Cable tray tee
Tue, Nov 1, 2016 at 7:29:06 AM
How to do Cable Tray with Real Material Color (Not just filter color)
Wed, Feb 18, 2015 at 3:14:07 AM
Tension Cable
Sun, May 27, 2012 at 6:54:39 AM
Cable Tray Clearance
Mon, Mar 24, 2014 at 10:44:48 AM
Cable Tray
Fri, May 9, 2008 at 7:28:19 AM
Page generation time: 2.5072
