75 Users Online (72 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Unwrapping circular wall in elevation
Fri, Oct 15, 2010 at 11:11:28 AM | Unwrapping circular wall in elevation
angedomi
 I will be working on a dome restoration project in which we would like to "un-roll" the elevations in order to show each bay and indicate the work to be done. Is there a way to do this in revit (v. 2011)? Can you change the straight line of an elevation to follow the line of the wall? Thanks for any advice.
Fri, Oct 15, 2010 at 4:22:22 PM | Unwrapping circular wall in elevation
Sorry but others have asked this question and I don't believe there is any way to do it.
I suggest you divide the wall in pie segments and take several smaller elevations and place those side to side.
Circular Arch
Tue, Jul 21, 2015 at 9:06:16 AM
circular stairs with spiraling wall around them
Tue, Mar 24, 2009 at 3:58:28 PM
spiral wall
Mon, Dec 22, 2003 at 1:08:25 PM
attachig walls to circular stairs
Wed, Feb 13, 2013 at 4:17:34 AM
curve wall in circular opening
Sat, May 17, 2008 at 3:38:01 PM
Page generation time: 0.8247
