72 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> printing on a1
Fri, Oct 15, 2010 at 4:40:01 AM | printing on a1
smriti1234
what should i set the properties/settings in the rendering toolbar so that the images which are produced after rendering are of high resolution so that they can be printed on a1 sheet(540mm X 890mm). the images which are generally/defualt are for very less pixels(20kb to 50kb.
i want to print these images on large sheets and the pixels break . please help me out..!!!
Sun, Oct 17, 2010 at 1:36:00 AM | printing on a1
revittutorialsonline
when you are in the view that you want to render, click on the view box and up the top you will see 'size crop'. make sure that you set one of these values (width or height) to that of the a1 sheet. i would typically set the width to 841mm to print the view at a1 landscape.
then in your rendering settings, make sure that you are rendering to 'print size' and not screen size.
tom
Printing Problems Revit 2012
Wed, May 16, 2012 at 7:31:02 AM
Fill Region set to Transparent but printing Opaque [ 1 2 ]
Sat, Jan 26, 2019 at 12:16:16 AM
17
Printing Query
Wed, May 23, 2012 at 7:54:09 AM
Printing
Thu, Jun 14, 2018 at 12:59:05 AM
some keynotes not printing
Thu, Sep 15, 2016 at 4:43:40 PM
Page generation time: 14.3355
