37 Users Online (36 Members):
Forums >> Revit Building >> Technical Support >> Phaseing Levels
39 Posts No Rating |
Hi, Revit Arch 2009 I'm busy with a Reno Project, where the existing house is going to be raised to build in underneath,,,,,I have Existing Site, Floor plan and elevations....Now I need to create proposed plans.....the problem is that when I change the levels for the reno showing the new levels my existing elevations levels also move....Is there any way to move existing structure on to new levels phased as proposed while keeping the same structure showing on the existing elevations as the levels it was? Cheers Ess
Anyone?
![Mr Spot Avatar](user_avatar/1073.jpg)
![4.5 Stars: 93 Votes](/images/stars_4.5.gif) |
The best way I've found to do this is by having 2 files. Link your existing building into a site file. Demolish the existing building and then place another instance as new construction at the relocated height. HTH.
Regards,
Chris.
Thanks Chris...I will give that a try ![Smile](/images/smiles/smile.gif) Cheers
Phaseing` |
Thu, Jun 28, 2007 at 10:54:04 AM
PHASEING HATCH LINES? |
Thu, Jan 11, 2007 at 4:43:26 AM
Replacing levels with ref planes or deleting excess levels |
Thu, Apr 17, 2008 at 11:10:37 AM
Levels missing Revit 2012 [ 1 2 ] |
Mon, Sep 28, 2015 at 3:29:41 PM
19
Levels, Disappeared. [ 1 2 ] |
Sun, Sep 24, 2017 at 7:44:33 AM
16
Members: | 2017275 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
