47 Users Online (46 Members):
Forums >> Revit Building >> Technical Support >> LOADING REVIT
1 Posts No Rating |
revit could not load revitMFC.dll, message keeps on coming up when trying to load revit 2010 any fixes TO THIS INSATLLATION PROBLEM
A google search returns this: Startup error: Revit could not load RevitMFC.dll All Autodesk application of the 2010 family (and higher) require the CPU instruction set "SSE2". This instruction extension is available in all newer processors by Intel and AMD. The installer checks (during installation) whether your processor (computer) is compatible but some older AMD processors slip through this test undetected. And the missing SSE2 instruction set then causes the "MFC could not load" error. You will need a newer PC to run Revit 2010. Is your computer/processor getting a little dated?? The next step would be to google your particular processor, SSE2 detection, see if there's a work-around. Sounds sort of dire--sorry.
LOADING COMPONENT [ 1 2 ] |
Sat, Apr 11, 2009 at 5:30:13 AM
24
Problem loading components |
Mon, Sep 28, 2009 at 3:43:40 AM
Loading Families |
Tue, Apr 21, 2009 at 4:41:24 PM
Loading file and autodesk.com |
Wed, Dec 9, 2015 at 7:34:06 AM
Errror loading door family |
Tue, Dec 1, 2009 at 10:10:48 PM
Members: | 2017200 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
