62 Users Online (61 Members):
Forums >> Revit Building >> Technical Support >> Perpsective Fill Patterns
30 Posts No Rating |
For some reason my fill patterns are not showing when I do a perspective veiw. I just want a hidden line perspective view but with the fill patterns (i.e. brick, siding...) just show up as solid dark shade. What am I doing wrong?
Help!
![5 Stars: 3 Votes](/images/stars_5.gif) |
You are probably using drafting pat. files. You want to make sure that you use model pattern files. Those show up in 3D.
Also when displaying you'll notice as you zoom out hatch patterns just to shading as they are too dense to display.
Try zooming in and see if they are appearing (if they are set to model patterns that is)
Just wanted to say thanks!
11 Posts No Rating |
Does this also apply to a 2x2 acoustical ceiling tile in perspective? Do the lines need to be model lines? Attached is a sample RCP and perspective view for reference. Thanks!
Fill Patterns |
Mon, Mar 10, 2008 at 6:40:09 AM
create/ convert hatch patterns (.pat) to revit fill patterns |
Tue, Jun 2, 2015 at 11:29:00 AM
Fill patterns, where are they? |
Tue, Mar 31, 2009 at 10:11:29 AM
Wall Fill Pattern question |
Tue, Oct 23, 2012 at 8:39:37 AM
Fill Pattern Weight |
Thu, Dec 17, 2009 at 12:03:13 PM
Members: | 2016882 | Objects: | 22944 | Forum Posts: | 152211 | Job Listings: | 3 |
