Forums >> Revit Building >> Technical Support >> Revit 2010 64 Bit
Are there other free PDF printers than cute pdf. Batcsplot function does not work on 64 bit Nicolai
97 Posts No Rating |
www.pdf995.com A free pdf driver. It is an advertisement driver, so you have to click a button to 'continue using the free version' when you create the pdf, but it works just fine. Not sure how the batch plot works with it... I've never tried that.
On cute's site, they say: - Added support for both 32-bit and 64-bit Windows 7.
 - Added support for both 32-bit and 64-bit Windows Vista.
- Added support for 64-bit Windows XP/2003.
I have the new cute pdf and it only works when you plot one at a time. I haven’t tried the pdf995. I will try it and hope for the best. Thanks for the help
" I have the new cute pdf and it only works when you plot one at a time. I haven’t tried the pdf995. I will try it and hope for the best. Thanks for the help " Same here thats why I use PDF Creator, it's slow but allows to have more sheets in a file.
I've been using DoPDF, it seems to work ok.
7 Posts No Rating |
We use PDFILL on both 32 and 64 bit Windows 7 http://pdfill.com/
2010 and vista 32-bit |
Thu, May 7, 2009 at 10:40:48 PM
11
Workshare monitor for 2010 64-Bit |
Wed, May 6, 2009 at 12:37:39 PM
Export from Revit 2010 32 and 64 bit to Atlantis 2 available |
Tue, May 26, 2009 at 11:34:30 AM
64 bit revit, 64 bit vista and multi-cores... [ 1 2 ] |
Sat, Apr 4, 2009 at 1:38:57 AM
29
Revit 2010 to 3ds Max 2010 Problem |
Thu, Jul 30, 2009 at 9:31:25 AM
Members: | 2119369 | Objects: | 23205 | Forum Posts: | 152302 | Job Listings: | 3 |
