54 Users Online (52 Members):
Forums >> Revit Building >> Technical Support >> Converting Autocad Layers to Standard Revit Linework
11 Posts No Rating |
I am using revit 2011. In the earlier versions there seems to be talk of an Import/Export table for layer conversion. I can only find export in 2011. How can I set layers up in autocad so the lines become lines I have already defined in Revit?
Are you talking exploded or imported CAD? Read this in your HELP: Setting Line Weights for Imported DWG or DXF Files and... For imported (linked) CAD, Manage Tab / Object Styles / Imported Objects.
Thanks I really appreciate the help.
1 Posts No Rating |
you can convert Autocad Layers to Standard Revit Linework by format conversion services. I downloaded Aide autocad to Revit Converter and Any revit Converter (http://www.formatconversion.biz), the programs worked great with converting.
AIA Standards- Revit to AutoCAD layers |
Thu, Feb 1, 2007 at 12:50:29 PM
Revit Load Layers from Standard |
Mon, May 2, 2016 at 2:28:08 PM
Changes to AutoCAD layers when imported to Revit |
Wed, Oct 29, 2008 at 10:35:39 AM
[Frustration] How to separate Autocad layers in Revit? |
Mon, Jun 25, 2012 at 11:31:55 AM
Importing Revit Layers into Auto CADD |
Mon, Nov 19, 2007 at 8:09:11 PM
Members: | 2017185 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
