32 Users Online (31 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Toposurface by points
Fri, Oct 8, 2010 at 5:07:55 PM | Toposurface by points
quentin4d
Surveyors provided me with this cad file of point / spot elevations in 3d. I importedCAD to Revit, and tried to make a toposurface.
First off it says "In your currently active view, topographic elements are not visible. You can change the visibility settings from the View menu, but it is recommended that you edit topography in either a Site view or a 3D view, as undesired clipping can occur in other views."...
but I am in a 3d view.
I continue with Create from Import, Finish Surface and nothing happens.
I also can't see the points in Revit that I see in Autocad, just the polyline.
Fri, Oct 8, 2010 at 5:38:45 PM | Toposurface by points
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Is Site/topography turned off in your 3D view?  Seems that's the gist of the error.  Survey data I've used flawlessly in the past were Plines, not points, so I wouldn't worry in that department.
Fri, Oct 8, 2010 at 5:50:31 PM | Toposurface by points
quentin4d
site / topography was not an option in Visibility Graphics Dialog
Possible to place contour lines to toposurface instead of points?
Fri, Jun 1, 2018 at 2:57:52 PM
Using Survey Data to create a toposurface
Mon, Oct 4, 2010 at 2:23:28 PM
Toposurface Contours
Mon, Aug 25, 2008 at 4:47:22 PM
toposurface problem!!!
Fri, Nov 5, 2010 at 7:40:03 AM
Flat Toposurface
Thu, Aug 3, 2017 at 8:58:49 AM
Page generation time: 0.2809
