93 Users Online (92 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> Interior/Exterior Lighting
Fri, Oct 8, 2010 at 10:51:42 AM | Interior/Exterior Lighting
lavendi321
4 Stars: 16 Votes
Has revit 2011 addressed the issue with interior and exterior lighting. I am using 2009 (i am upgrading to 2011 in a few days) and was windering if Revit 2011 resolved the issue with interior artifical lighting, and exterior sun lighting?
If I do an interior rendering with artifical lights, can i still get some ambient lighting from exterior sun?
Thanks
Fri, Oct 8, 2010 at 12:03:01 PM | Interior/Exterior Lighting
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
I haven't ever heard of this issue.... Are you not using daylight portals?
Fri, Oct 8, 2010 at 12:14:16 PM | Interior/Exterior Lighting
lavendi321
4 Stars: 16 Votes
in Revit 2009, I hav read, and seen when I do interior renderings, that if I use Interior with Sun and Atificial Lighting, the Interior lights are so dim, they do not evenshow up. I read on here, that one way to resolve this is to over brighten the interior lights by almost 150% (light intensity). I have used daylight portals also, but when I do an interior rendering, with sun light, then interior is dark, like NO SUN is filtering in through the windows.
Fri, Oct 8, 2010 at 12:39:55 PM | Interior/Exterior Lighting
alabaster2513
3.5 Stars: 25 Votes
try changing your time of day just after dusk or before dawn, you'll get ambient light from the sky not direct light from the sun
Fri, Oct 8, 2010 at 12:53:06 PM | Interior/Exterior Lighting
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Nope the issue still exists...
Regards,
Chris.
interior lighting for exterior rendering [ 1 2 ]
Thu, Feb 11, 2016 at 2:03:05 PM
16
Interior Lighting from an exterior view
Wed, Nov 11, 2009 at 12:41:45 PM
Exterior/Interior Lighting in High Quality Rendering
Wed, Mar 18, 2015 at 4:16:34 PM
exterior to interior walkthrough in Revit 2010
Wed, Aug 11, 2010 at 3:03:04 PM
exterior lighting HELP
Tue, Feb 14, 2012 at 4:14:00 PM
Page generation time: 1.0429
