77 Users Online (75 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Ceiling not bounding room
Wed, Oct 6, 2010 at 3:32:50 PM | Ceiling not bounding room
leothelionator
I have a simple room with a simple ceiling that is set to Room Bounding.  However, the room is not recognizing the ceiling as a room bounding element.  It displays the default 10'-0" instead.  How do I get the room to recognize the ceiling as room bounding?
Wed, Oct 6, 2010 at 4:01:35 PM | Ceiling not bounding room
leothelionator
I think I figured it out.  Incidentally, I am using Revit 2011, which does not calculate the room height automatically like pre-2011 did.
You must first enable Volume by doing the following:
http://docs.autodesk.com/REVIT/2011/ENU/filesUsersGuide/WS1a9193826455f5ff-54f556ca1166ac9ee9e-4abf.htm
Then set a formula for the ceiling height by doing the following:
http://revit.blogspot.com/2009/04/tagging-ceiling-heights-in-room.html
I'll let you know if I run into any problems.
Trouble getting furr down walls @ ceiling to actually be room bounding..........
Tue, Jan 26, 2010 at 11:58:10 AM
how to UPDATE Room Bounding Limit
Mon, Apr 18, 2011 at 12:04:01 PM
room bounding problem
Fri, Jul 28, 2017 at 4:03:50 AM
13
2009 ROOM BOUNDING - non enclosed errors
Thu, Jul 24, 2008 at 9:28:34 PM
Stairs as Room Bounding
Mon, Jul 9, 2007 at 10:34:26 PM
Page generation time: 0.5438
