Forums >> Revit Building >> Technical Support >> Trying to create a Plan Title with a rotating north arrow
Wed, Oct 6, 2010 at 2:29:27 PM | Trying to create a Plan Title with a rotating north arrow
kevinb13
Long time reader, first time poster!!
Using Revit 2011, I am trying to create a Plan Title that has a built in north arrow where the north arrow can rotate.  What I am having problems with is getting the north arrow to rotate it.  I drew the north arrow using line under the home tab in the family editor, turned it into a detail group and that is as far as I can get it.
I would like to have an option where this can be rotated without the north arrow being it's own separate family.  Any assistance with this would be greatly appreciated.  I have attached the file so you can see where I am so far.
Wed, Oct 6, 2010 at 3:22:51 PM | Trying to create a Plan Title with a rotating north arrow
TKennedy
4 Stars: 7 Votes
I would try making the arrow as a symbol, then nesting that in the plan title family. You should then be able to align/lock/rotate it.
I have had terrible luck getting anything more complex than a couple of lines to rotate, I always end up making the geometry I need rotated in a nested family.
Thu, Oct 7, 2010 at 9:12:40 AM | Trying to create a Plan Title with a rotating north arrow
You might be able to do this as a nested family and using a type in the title family to rotate it.  We settled a long time ago on 4 titles with project norths set at NSEW.  That hasn't been worth changing since you only usually need one of those in a project.
This user is online
Wed, Oct 13, 2010 at 8:14:48 AM | Trying to create a Plan Title with a rotating north arrow
kevinb13
Thanks for this, nesting the object gave me a good starting point..
Now the problem I am having is since I created a separate north arrow and brought it into the view title, it rotates great; but when I bring that view title into my project, my ability to rotate the north arrow disappears...what I would like to do is be able to have an option to rotate the north arrow in my project by typing in an angle.
Any ideas?
Wed, Oct 13, 2010 at 8:27:28 AM | Trying to create a Plan Title with a rotating north arrow
Did you look at making that angle a TYPE property - not instance?
This user is online
Wed, Oct 13, 2010 at 9:51:08 AM | Trying to create a Plan Title with a rotating north arrow
kevinb13
I did have it as an instance property...but am still having the same issue after changing it to a type property
I am attaching what I've created so far
North Arrow
Tue, Jan 16, 2007 at 9:24:44 PM
Rotating Project North and Sheet view North not rotating
Mon, Oct 12, 2009 at 9:34:25 AM
Rotatable North Arrow
Mon, Dec 29, 2008 at 6:02:48 PM
View Title with North Arrow and Shared Parameters?
Thu, Aug 6, 2009 at 4:28:58 PM
North Arrow
Fri, May 6, 2016 at 7:09:47 AM
Page generation time: 2.8586
