50 Users Online (48 Members):
Forums >> Revit Structure >> Technical Support >> Footings not showing up correctly
38 Posts No Rating |
RST 2011 Where a continuous footing meets with an isolated pad, the lines kind of overlap. All the elevations are correct and I have done join geometry, which didn't do anything. I want the footing lines to be continuous. How can I make this happen?
![4 Stars: 7 Votes](/images/stars_4.gif) |
It's been a while since I've made any footings, but here is what I can remember: Top of footing has to be exactly the same. Sometimes you have to use join geometry (sounds like you've done both of those) and if I recall correctly, the material needs to be the same.
![4 Stars: 1 Votes](/images/stars_4.gif) |
davidlowery, I think you are seeing lines where the continuous footing meets the isolated pad because the thickness of the isolated pad is greater than the thickness of the continuous footing. When the thickness of the isolated and continous footings are the same the lines to not show up where the two meet.
isolated footings not showing up |
Wed, Jul 18, 2012 at 1:17:11 PM
Footings for Slab Foundation |
Tue, Oct 30, 2007 at 7:05:08 AM
Auto Footings |
Tue, Apr 4, 2006 at 10:10:15 PM
Footings, getting double hidden lines and intersections suck! |
Fri, Aug 31, 2012 at 10:13:08 AM
toposurface adjusts to linked model footings |
Sat, Oct 22, 2011 at 10:11:33 AM
Members: | 2022335 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
