53 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> {3D} Default view transparent
Sun, Oct 3, 2010 at 11:38:04 AM | {3D} Default view transparent
seeb
2 Stars: 1 Votes
Hi all,
When I create a 3D view the model is displayed transparent. Is there a way to get around this problem. See attachment please.
Thanks
Sun, Oct 3, 2010 at 4:09:49 PM | {3D} Default view transparent
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
To me it looks as though someone has selected two of your external walls and chosen them to be hidden in view through override element.
Select the "Reveal hidden elements" command (the light bulb), and they should appear in dark red.  Select each of them and then in the ribbon choose "unhide element".
Regards,
Chris.
Mon, Oct 4, 2010 at 9:07:24 AM | {3D} Default view transparent
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
Ya.. it looks like it got overriden.... It could also be a graphx card issue.
 "If you tell the truth, you don't have to remember anything"
Mon, Oct 4, 2010 at 8:00:55 PM | {3D} Default view transparent
seeb
2 Stars: 1 Votes
The walls are there, but when looking at them head on they become transparent, when I rotate the model to the other side of the building the walls that were transparent become solid and visible and the walls that were visible become transparent. So in a way you can always see through the building!
I have attached two images. The first one is the north view and the second one is the south view of same model. I hope I am clear this time.
Thanks
Tue, Oct 5, 2010 at 1:41:47 AM | {3D} Default view transparent
gebber
gebber Avatar
5 Stars: 4 Votes
It looks like you've set the wall to be transperant.
Select the wall
And check the material properties.
Make sure the transperancy is set to 0%
Tue, Oct 5, 2010 at 5:32:57 AM | {3D} Default view transparent
4 Stars: 203 Votes
Also, like we can see you can select the wall, so, select the wall, right-click in your mouse then go to "Override Graphics in view > by Element" and see if you have the "Transparent" check, if you have just uncheck.
HTH
Tue, Oct 5, 2010 at 9:03:41 PM | {3D} Default view transparent
seeb
2 Stars: 1 Votes
Thanks gebber! It turned out the wall exterior surface material had the transparency of 75% causing the problem.
Mon, Dec 7, 2015 at 4:12:20 AM | {3D} Default view transparent
rnorrish
Just a note, it seems if all the above are in order, or if the walls suddenly change to a transparent (around 10%) look, you will have  something stuck in the wall. For example, I just chaged the thickness and materials of a wall familty and had this problem. after some review of the job it was a few items ( plumbing fixtures) that had been affected and not were partially in the wall. I re located these to sit against the wall instead of inside it and all fixed.
Edited on: Mon, Dec 7, 2015 at 4:13:47 AM
Tue, Mar 24, 2009 at 6:31:57 PM
Transparent object
Tue, Sep 14, 2010 at 1:18:35 PM
Where's my default 3D view?
Wed, May 6, 2009 at 9:44:53 AM
Set default 3D view
Tue, Feb 18, 2014 at 11:31:44 AM
True 2d projection from tilted wall
Sun, Apr 24, 2011 at 10:00:20 AM
Page generation time: 1.5075
