88 Users Online (87 Members):
Forums >> Revit Building >> Technical Support >> Self-Changing Cutrain Walls
![Scrybe Avatar](user_avatar/152386.jpg)
7 Posts No Rating |
I'm attempting to place a curtain wall-storefront in a project in RA'11. I want the total system to be only 12'-0" long from one specific point to another. But, every time I attempt to do this, the wall readjusts itself so that at least one mullion edge (if not both) jumps all the way to the nearest wall join. I've adjusted every setting that I can think of, and I can't seem to stop it from doing that. Am I missing a setting somewhere? Anyone have any ideas?
It sounds as though you have rules for grid placement set up in your storefront glazing system. Edit its type and remove the rules for vertical grid spacing (or change them to what you need them to be), and place the grids manually where you require them. HTH.
Regards,
Chris.
CHanging color of walls/roofs |
Tue, Oct 31, 2006 at 8:54:31 AM
Changing wall thickness issue |
Thu, Oct 12, 2006 at 11:07:14 AM
Changing display of walls below current level. |
Wed, Jun 18, 2014 at 7:36:35 AM
Maintaining interior dimensions when changing walls |
Mon, Mar 16, 2009 at 11:19:25 AM
changing grid lines angle - walls are detached |
Fri, Apr 20, 2007 at 6:29:43 PM
Members: | 2017021 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
