90 Users Online (88 Members):
Forums >> Revit Building >> Technical Support >> Raking Windows
2 Posts No Rating |
I've created a sloping wall made of windows that are from floor to ceiling. I've modelled the windows as generic models and have made them workplane based. The issue i have is that it will not cut in plan. Is the only option to create "model lines" at the cut plane and turn off the window? Cheers
Why would you create windows as generic models? They are windows so create them that way, as you discribe it, it even sounds like it is a curtain wall. Every kind of family works according its own principles, a generic model should't be cut so thats why it doen't cut. Anyway; select the component go to edit family. Here you click family catagory and parameters here you can choose a diferent catagory some will cut in planview.
If you search your HELP with the term cutable, you can learn which categories will cut. And I agree with gebber, set the category to window where it belongs. You can start with the generic template if you wish but change the category under options and parameters.
LT2014 - Ceiling Based Model Disappears Halfway Across Raking Ceiling |
Wed, Sep 4, 2013 at 7:24:16 AM
Raking sweeps |
Thu, Jul 20, 2006 at 3:10:24 PM
Raking curtain walls, adding tags to Shop Front glazing |
Tue, Mar 7, 2006 at 9:35:58 PM
My Windows are not in my Windows Tab |
Tue, Dec 15, 2009 at 7:02:38 AM
Does Revit 2009/2010 work properly to on Windows 7 |
Thu, Jun 3, 2010 at 4:25:04 AM
12
Members: | 2026530 | Objects: | 22993 | Forum Posts: | 152211 | Job Listings: | 3 |
