38 Users Online (37 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit ROI >> Printing from Revit 2011 with cutepdf
Thu, Sep 30, 2010 at 10:21:03 PM | Printing from Revit 2011 with cutepdf
kg01
Hi, I'm new to Revit 2011 and am trying to print a sheet to pdf, I can get it to print to cutepdf but it doesnt print the whole sheet, it cuts off 1/3 of it to the side, I cant find a setting to fix this, does anyone know how to print (to scale) to pdf from Revit 2011?
Fri, Oct 1, 2010 at 1:46:01 AM | Printing from Revit 2011 with cutepdf
gebber
gebber Avatar
5 Stars: 4 Votes
In the print menu go to setup.
In the setup choose zoom 100%
btw. I'm using PDF creater, works fine also for creating sets but is a bit slow.
Maybe someone has another sugestion?
Fri, Oct 1, 2010 at 6:39:09 AM | Printing from Revit 2011 with cutepdf
We use cute for all of our PDF's and have done so for several years so I know that is not a problem.
In your print setup, it sounds like you have chosen the wrong option in what to print.  You have an option of printing the current view window which is usually just a little bigger than what you see on screen or you can print the complete view/sheet.  The scale should be 100% if you want to print the view or sheet at the scale you have laid it out as and if you have picked the right sheet to print it on.
Mon, Oct 4, 2010 at 4:16:01 PM | Printing from Revit 2011 with cutepdf
kg01
Thanks for your replies, I am selecting the sheets to print in the view/sheet set setting, I am also setting the zoom to 100% however I am still having the problem. I am trying to print a sheet but it seems to be printing from the edge of the viewport instead of from the borders of my sheet and titel block. Does anyone know how to fix this?Thanks.
Mon, Oct 4, 2010 at 5:47:46 PM | Printing from Revit 2011 with cutepdf
mcantwell
mcantwell Avatar
Sometimes there are hidden items that make the centre of the print move in one direction or another. Open the title sheet and make sure that no reference lines or text run off the print area.
Also check for section markers in the view and resize or hide in view.
Check orientation in cutepdf and the revit setup.
Matt
(cute pdf user (the pdf not the user))
Tue, Oct 5, 2010 at 8:05:08 AM | Printing from Revit 2011 with cutepdf
Are you printing view crop boundaries?  If that extends past your sheet well then .... of course it starts with the crop boundry.  You can check the box "hide crop boundries" in the print setup menu.
PRINTING ISSUES. When printing to CutePDF my drawings won't come out to scale.
Tue, Sep 6, 2011 at 7:51:06 AM
Lines Greyed-out, but Annotations Not When Printing with CutePDF
Thu, Dec 6, 2012 at 7:52:16 AM
CutePDF stopped Working. Any alternatives?
Mon, May 3, 2021 at 7:35:28 AM
PDF printing problems
Tue, Dec 3, 2013 at 7:16:18 AM
Missing Text with Cutepdf writer ?
Fri, Jan 19, 2018 at 12:00:21 AM
Page generation time: 2.2616
