Forums >> General Discussion >> Revit Project Management >> revit 2011 image
23 Posts No Rating |
when we open revit architecture 2011.. 1 image comes up..!! how can i make this type of wall...??? is dis project any how downloadable?? even if not, please can some 1 tell me how to make dis?? i have attched a few images as to how it looks.... plzzzzz reply soon..!!!
Someone here or on AUGI or in a blog somewhere showed how this one was done. I can not remember where .... But have you looked at the standard materials?
Edited on: Wed, Sep 29, 2010 at 9:32:12 AM
curtain wall with a custom panel and or material
really...when where... can any1 please help..!! i hav seen many versions on dis thing... i guess sum where it might be available to be download..!!
@alabaster2513 can u plz explain i little as to how to do it>???
1 Posts No Rating |
hi.... i'm not very good in english but i try to tell u how to make it!
first u should have a black&white pattern for your favorite wall.
second you can make your wall with mass or model in place.
i make it in MODEL IN PLACE/EXTRUSION.
after that, put your material(reflective is better).
in CUTOFF tab, put your pattern with favorite scale.
finally u can render it. good luck!
Image Map in 2011 |
Thu, Nov 11, 2010 at 6:05:23 AM
HOW DO I PRINT MY JPEG IMAGE? |
Mon, Jun 4, 2012 at 7:09:49 AM
REVIT ARCH 2011 render problems |
Fri, Sep 16, 2011 at 2:04:13 PM
Make imported image NON-SELECTABLE (not just pinned) |
Fri, Sep 25, 2015 at 7:34:24 AM
Sun Path in Revit 2011 |
Fri, Apr 30, 2010 at 3:43:31 AM
Members: | 2119292 | Objects: | 23205 | Forum Posts: | 152300 | Job Listings: | 3 |
