45 Users Online (44 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Parameters with negative values
Wed, Sep 29, 2010 at 4:24:45 AM | Parameters with negative values
archie456
3 Stars: 1 Votes
Hi,
I feel like this is a stupid question, but I can’t work out the answer, so I apologies if this is something obvious.
How do I set a parameter to a negative value when used for moving a Ref Plane?
I am creating a new custom door, and I want to be able to move the frame within the wall from the centre line, I have a parameter from the centre line to the frame.
This works fine if I want to move the door ‘north’ of the wall, I just type the value into the parameter. But I cannot move it ‘south’, I would expect to type in a minus figure, but Revit won’t accept this – “Parameter Door Offset has an invalid value.”
I can drag the Ref Plane manually to set it in the family editor – but if I drag it ‘South’ the figure in the Family Types dialog is always positive.
Am I missing something??
Cheers.
Wed, Sep 29, 2010 at 7:08:27 AM | Parameters with negative values
As far as I know, you can't do a negative.  I always set up a base reference plane far enough to one side that my value will always be positive.
Fri, May 13, 2011 at 10:40:41 AM | Parameters with negative values
mccoolj
I too ran into the same roadblock on stuff where referencing from centerline is preferable. You can use the flip controls when you're creating your family to work around it (i.e. dimension outward by the amount you're wanting to dimension inwards, then flip the item so it's now on the other side of the reference line.
using schedule keys, shared parameters and calculated values in schematic design
Tue, Mar 6, 2007 at 1:41:37 PM
Instance Parameters Resetting
Mon, Jan 28, 2019 at 1:20:32 PM
Room parameters
Sun, Mar 30, 2014 at 1:22:56 PM
Material Library with custom parameters.
Fri, May 6, 2016 at 3:36:30 PM
Blank values in parameters
Thu, Oct 3, 2013 at 7:16:06 AM
Page generation time: 0.8305
