118 Users Online (117 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Railing
Tue, Sep 28, 2010 at 11:47:31 PM | Railing
Rgoldie13
How do I create a criss/cross Railing.  Old Queenslander style.
Wed, Sep 29, 2010 at 3:35:12 AM | Railing
dafoles
Find a railing that has a decent base point of what you are after. Maybe a few balusters and top and bottom rail. Then you will need to edit the railing properties. Pretty easy to do. Just play around with the settings and you may need to edit the baluster families and railing families to get the look you are after.
 You can really do some great things with railings. You can build an entire stair by using a railing.
Wed, Sep 29, 2010 at 5:53:06 AM | Railing
4 Stars: 203 Votes
Search in Net for "Insanely Great Stairs and Railings with Autodesk® Revit® - Phil Read – HNTB Companies"
Thu, Sep 30, 2010 at 12:27:59 AM | Railing
Rgoldie13
Thanks for the response, I started by duplicating an existing family and have midified it to the extent of removal of existing posts and balusters retaining only the rails. I need to insert a post at centre span and the balusters need to be raked to form an X shape. See PDF attached.
 Thanks
Railing not shown in list
Mon, Jun 30, 2014 at 4:25:57 PM
rectangular railing
Mon, Nov 26, 2012 at 7:30:08 AM
Railing Turns Into Transparent Red
Thu, Aug 10, 2017 at 2:06:42 AM
Railing and Baluster Profiles not inserting on centerline?
Fri, Oct 5, 2012 at 2:26:21 PM
Newbie help: how to intersect railing with baluster
Wed, Mar 25, 2009 at 4:26:54 AM
Page generation time: 0.2438
