34 Users Online (31 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Wishlist >> detail lines WITHIN wall types
Wed, Oct 19, 2005 at 6:21:36 PM | detail lines WITHIN wall types
Chymos
It would be nice to be able to add detail lines to wall types. We frequently use dashed lines to indicate fire rated walls (and insulation lines to show sound attenuation). These dashed lines are typically drawn along the centerline of the major structural element simply for readability issues. Would it be possible to add this dashed line to the wall type or must we continue using unintelligent detail lines?
Wed, Jul 11, 2007 at 6:26:11 PM | detail lines WITHIN wall types
imahsome
Wall's graphical properties seem to be fairly limited right now...I would just say use the pick line tool with the desired linetype on the walls' centerlines. It would be nice to be able to change wall hatch thicknesses to to other linewieghts besides "1".
Can you convert model lines to detail lines?
Wed, Mar 31, 2010 at 12:45:23 PM
Changing line types and styles in cross section views, wall types etc...
Wed, Apr 12, 2006 at 12:52:32 AM
How do you hide the joint lines between different wall types?
Fri, Nov 16, 2007 at 8:16:34 AM
Lines from different wall types showing up in elevation
Tue, Sep 24, 2013 at 10:07:46 PM
Copying Arch Wall Types
Tue, Aug 14, 2012 at 9:18:26 AM
Page generation time: 1.2508
