Forums >> Revit Building >> Technical Support >> Revit 2010 won't start up
3 Posts No Rating |
I'm trying to get Revit 2010 going on a laptop that used to run it, but hasn't been used in a while. After only a couple of seconds load time, I get the error "An unrecoverable error has occurred. the program will now be terminated. All of your data has been recently saved, so there..." I've seen this in other posts, but the fact that the machine used to run Revit just fine makes it seem like performance capacity shouldn't be an option. If it helps, here's the journal: ' 0:< Initial VM measure: 1931 MB available, 37 MB used 'C 27-Sep-2010 15:06:22.421; 0:< started recording journal file ' Build: 20090917_1515Dim JrnSet Jrn = CrsJournalScript'C 27-Sep-2010 15:06:22.437; 0:< ->InitInstance ' 0:< VM Delta: Available -215 MB -> 1716 MB, Used +82 MB -> 119 MB ' 0:< Exception occurred ' 0:< ExceptionCode=0xe0434f4d ExceptionFlags=0x00000001 ExceptionAddress=7C812AFB ' 0:< System (KB) [Available / Total ] [Revit Memory Usage (KB) ---------------- ] ' 0:< RAM Statistics: 2811068 / 3667860 157432=InUse 157516=Peak 699360=DeltaForRevit ' 0:< VM Statistics: 1758036 / 2097024 122760=InUse 122932=Peak 216228=DeltaForRevit ' 0:< MessageBox "An unrecoverable error has occurred. The program will now be terminated. All of your data has been recently saved, so there is no need to create recovery files." ' 0:< VM Delta: Available -29 MB -> 1688 MB, Used +12 MB -> 132 MB 'C 27-Sep-2010 15:06:25.328; 0:< program terminated Any help would be very appreciated, thanks! Kevin
GoatsHead- well i guess if it won't start up- then that probably means it won't run.. and if it won't run then that means it needs to be reinstalled.. depending on the speed of your processor- i just tested it)- it took me 15 seconds to unistall revit and 2 minutes and 10 seconds to reinstall it.. if it still doesn't run after that- then reinstall windows..
Ghostyhead, maybe this can help you: Revit 2010/2011 won´t run or start up
“Learning never exhausts the mind.” — Leonardo Da Vinci
3 Posts No Rating |
Dung- Have uninstalled/reinstalled a couple of times now, and I'm trying to avoid reinstalling Windows. Other thoughts? Erland- Thanks for the site, but the file it specifies for to remove doesn't seem to exist on my computer. Actually, I find the site odd in that it says "if the file exists", but doesn't give a solution for if it doesn't. Thanks again guys.
Assuming that you have no platform or equipment issues then I would look again at erlands answer. I know you said you didn't find it but do a file search for "WSCommCntrData.xml. That file is tpically the problem.
sometimes I have to force quit wscomcntr1.exe (sp?) in the task manager to get autodesk programs to launch. most common after a crash or repeated opening and closing of files.
3 Posts No Rating |
WWhub/erland: Did searches on my entire C drive for "WSCommcntrdata" as well as other key phrases in the mentioned filepath, with no results. lunchtray: The process isn't running according to my task manager, so unfortunately no go.
Although you don't mention what Windows you are using, "Application Data" (XP) or "Appdata" (Vista), is a hidden folder, that's why you can't see it......
Revit Structure 2010 won't start!!! Help!!! [ 1 2 ] |
Mon, Oct 8, 2012 at 11:20:43 PM
18
Revit won't start again (i have to restart) [ 1 2 ] |
Thu, May 26, 2011 at 6:07:38 PM
20
revit won't start |
Thu, Nov 3, 2005 at 10:50:46 PM
revit MEP 2016 won't open |
Tue, Aug 15, 2017 at 9:58:04 PM
Some furniture won't display |
Wed, Jul 12, 2006 at 5:39:41 PM
Members: | 2100884 | Objects: | 23171 | Forum Posts: | 152296 | Job Listings: | 3 |
