54 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> custom pat files
Wed, Oct 19, 2005 at 4:53:28 PM | custom pat files
arccodex1
3 Stars: 1 Votes
I've been trying to find a way to create custom pat files from AutoCAD 2004. Is there a program or LISP routine out there?
Wed, Oct 19, 2005 at 6:14:01 PM | RE: custom pat files
TomDorner
4.5 Stars: 25 Votes
Try this: http://www.cadro.com.au/hatchkit/index.html Also remember that any existing ACAD .pat file can be made into a Revit fill pattern in a text editor by simply adding a new line of text. Tom
Thu, Oct 20, 2005 at 9:59:09 AM | RE: custom pat files
nextvkin
Tom, That sounds interesting, but what's that new line of text consist of?
Thu, Oct 20, 2005 at 10:29:12 AM | RE: custom pat files
TomDorner
4.5 Stars: 25 Votes
From the Revit help file:
To create a pattern file, you use this format:
Units
;%UNITS=INCH
Header
*pattern-name, [optional description]
Type declaration:
;%TYPE=MODEL (this is line to add to .pat file, it can be MODEL or DRAFTING)
Pattern descriptors:
angle, x-origin, y-origin, shift, spacing
Simple pattern definition sample:
*Block 4x12, 4 x 12 blocks running bond
;%TYPE=MODEL
0, 0, 0, 0, 4
90, 0, 0, 4, 6, 4, -4
Thu, Oct 20, 2005 at 1:45:30 PM | RE: custom pat files
arccodex1
3 Stars: 1 Votes
I downloaded HatchKit and I've been working with it. It seems like the pattern is so dense when I import it into Revit that it appears like a solid fill. Are there guidelines for scaling patterns in HatchKit so that they display appropriately in Revit?
Thu, Oct 20, 2005 at 1:49:40 PM | RE: custom pat files
TomDorner
4.5 Stars: 25 Votes
The only method of scaling seems to be trial and error. I'm sure there is some underlying math in Revit taking place but as a user it's logic doesn't seem to be exposed to me. Tom
Thu, Oct 20, 2005 at 3:10:16 PM | RE: custom pat files
arccodex1
3 Stars: 1 Votes
I had to buy the program for it to work properly. The demonstration logo that HatchKit inserts into pat files causes a lot of grief with scale issues.
Thu, Oct 20, 2005 at 4:46:58 PM | RE: custom pat files
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I typically draw the pattern i want in autocad/revit then import to hatchkit. And save the pattern from there to use in revit. This should give you the appropriate scale. Also when importing to revit you can change the scale then...
Fri, Oct 21, 2005 at 3:13:23 PM | RE: custom pat files
arccodex1
3 Stars: 1 Votes
Ok, I've been building my own pat files with HatchKit. Is it just me or does Revit only accept patterns up to 2'. If I try to scale a pattern to more than 2' in either HatchKit or Revit I get a message from Revit telling me that the pattern is too big.
Import PAT File
Tue, Dec 14, 2010 at 9:42:43 AM
Pat Files
Thu, Jan 22, 2009 at 1:26:47 PM
looking for .pat files [ 1 2 ]
Tue, Dec 1, 2020 at 1:43:31 PM
24
Use Pat Files
Tue, Sep 1, 2009 at 4:18:40 AM
11
Is there a way to preview .pat files / hatch patterns in thumbnails in a folder?
Mon, Jul 6, 2015 at 11:01:26 AM
Page generation time: 1.3010
