Forums >> Revit Building >> Technical Support >> User Interface help: Help? please urgent
4 Posts No Rating |
I upgraded to 2011 and so far things had been going smoothly, however I opened revit today to find my project properties box, and elements box completely overtake the screen, and there's no way to minimize the windows(or it won't allow me) I just toggle between my views and project browser using a keyboard shortcut, and the element properties window is so wide I can't even make edits to anything. help please.
It's a BUG, Just follow this: http://revitclinic.typepad.com/my_weblog/2010/07/revit-2011-hangs-at-splash-screen-or-crashes-with-unrecoverable-error.html?utm_source=feedburner&utm_medium=feed&utm_campaign=Feed%3A+typepad%2Ftherevitclinic+%28The+Revit+Clinic%29
Edited on: Sun, Sep 26, 2010 at 7:23:04 AM
5 Posts No Rating |
Hello Typhoon, I had the same problem, but now, if I activate the Project Browser and the Properties Toolbars, from the >View>User Interface menu, a blank screen appears, the only way of seeing the project is by unchecking the Project Browser and the Properties boxes. (See images) I tried with the link that you posted, following all the options, but it didn't work. Help please. Best regards!
4 Posts No Rating |
So yes indeed i tried all three solutions on the website and even had the autodesk website reset my interface but iøm still getting the same error. sorry for the hiatus, i had to finsih a project but i had to find a way to work around this problem. I am defintely worried though because Iøm having the same issues: my project browser fills up the entire screen I have to exit out to see my project and toggle back and forth, and my element properties box is a blan k screen now. I don't know what to do esp. considering i have another project due soon and i can't edit anything really.
Ok, i forgot one thing, close REVIT and go to that folder and delete the UIState.dat Windows XP C:\Documents and Settings\%username%\Local Settings\Application Data\Autodesk\Revit\\UIState.dat
Windows Vista & Windows 7 C:\Users\%username%\Appdata\local\Autodesk\Revit\\UIState.dat
After this just run this file i just attached now, click "Executar" then "Sim" then "Ok", it gonna fix the problem.
Edited on: Thu, Sep 30, 2010 at 1:36:47 PM
5 Posts No Rating |
Typhoon you rock!!! Thank you very much!! I was desperate! about to throw this computer away! hahaha It worked as magic! I'll be glad to buy you a beer whenever you are in Mexico! Take care! and thanks again.
4 Posts No Rating |
iøm not sure why iøm having so much trouble with this but i can't find the UISTAT.DAT file, and everytime i go t download the attachment it comes in as an mp3 file for some reason. sigh i don't understand why i'm having so much trouble with this, i think i'm computer illiterate maybe i should just uninstall and re install revit.
4 Posts No Rating |
`good news i downloaded the newest updates for 2011 and it was fixed thanks guys for all your help.
Edited on: Thu, Sep 30, 2010 at 5:38:46 PM
1 Posts No Rating |
Hello Typhoon,
I'm getting the same problem. My properties and project browser boxes are filling the whole screen. I've tried all 3 options and nothing works...
I was wondering... where do i find this file you say you uploaded??? I'm talking about the one we have to "execute" after having deleted the UIState.dat
Hope to solve this issue... When openning the same file on other computers, I don't have this problem. It's only on my workstation.
Thanks! Hope you can help me!
I do not know if it was because the last attack but the file is gone, sorry for that but here you have again the file attached.
Cheers
Edited on: Tue, Apr 12, 2011 at 1:58:59 PM
Revit Architecture 09 - User Interface |
Thu, May 29, 2008 at 3:27:12 PM
Setting User Interface |
Tue, Aug 14, 2007 at 5:03:40 PM
Accurender file location |
Sat, Nov 1, 2008 at 9:29:54 AM
Stop the yearly interface updates |
Fri, May 13, 2011 at 8:38:20 AM
Can I reinstall Revit 2015 trial version? |
Tue, Dec 9, 2014 at 3:36:39 PM
Members: | 2022237 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
