36 Users Online (35 Members):
Forums >> Revit Building >> Technical Support >> Applying Parameters to sweeps
3 Posts No Rating |
I am trying to make a Parametric. I seem to not be able to apply a depth parameter. I Have tried everything to know avail. This is a sink for a commercial kitchen. The profile is shaped like a fishhook extending down vertical from the drainboard top about 10" inches straight and then a 3/4" radius at the bottom end which forms the cove. The profile is 3/16" thick the entire length including the radius at the bottom end. I can make the sink no problem the sketch path is connected to the drainboard reference plane. I use an extrusion for the bottom which is also 3/16" thick. When i dimension and apply the parameter for sink depth it will not stretch down or up for that matter. I gave up and tried a different method to make a solid extrusion for the sink and then a void extrusion to carve out the sink. There are two many pieces and procedures to make this a practical solution. I know this can work as a sweep and one extrusion for the bottom. I would really appreciate any help to make this work. I am using Revit Architecture 2011. Thank you in advance for your help! David
3 Posts No Rating |
After 4 days of research i finally found my answer. Was not all wasted though i learned a lot about everything else. The problem was with the profile Arc point at the bottom was not locked to the reference plane that i labeled "SinkBottom". I finally discovered the problem and quickly found the solution. Thanks anyway.
In-Place Family sweeps issue |
Tue, May 15, 2007 at 4:56:50 PM
Revit 2012 crashes applying wall sweeps |
Tue, Feb 26, 2013 at 9:43:55 PM
Problem connecting wall sweeps (horizontal and vertical) |
Fri, May 4, 2012 at 2:07:26 PM
Angling Wall Sweeps |
Mon, Aug 15, 2011 at 1:26:41 PM
Family material parameters duplicating issue |
Tue, Mar 11, 2014 at 2:27:48 AM
Members: | 2022388 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
