143 Users Online (141 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> can Callout duplicate detailed drawn on section view?
Thu, Sep 23, 2010 at 7:14:24 PM | can Callout duplicate detailed drawn on section view?
williamsham
I have some details I drew on a section view, then I made call out of those detail. In the callout, i'll put in even more detail.
Is there a way to duplicate the details I drew on the section view in the callout automatically (like a mirror)
They're all detail lines.
Thank you.
Thu, Sep 23, 2010 at 11:21:08 PM | can Callout duplicate detailed drawn on section view?
eldados
eldados Avatar
4.5 Stars: 8 Votes
Detail (drafting) lines are view specific, you can't create a call out that will show these lines, but...
you can create the callout and copy paste the line work
or
you can duplicate the view with detailing which will take all your lines across
or
you can freeze the view to create a new drafting view out of it...
Integrator
KarelCAD
Fri, Sep 24, 2010 at 7:32:26 AM | can Callout duplicate detailed drawn on section view?
Model view callouts are exactly the same place as the parent view so when you copy from the parent, you can paste same place to the detail or vice versa. Just window and filter for what you want.
When I update items like this, I often erase the detail elements that were there in the destination view and then I don't have to be as selective in the copy.
Mon, Sep 27, 2010 at 12:36:18 PM | can Callout duplicate detailed drawn on section view?
mccga
you can create a detail group of the "macro" detailing and copy the group to the "micro" detail.  if you change the macro, the micro will update or vice versa.  you can also include detail components.
Thu, Oct 4, 2012 at 11:05:02 AM | can Callout duplicate detailed drawn on section view?
jamesfroese
how do you copy and paste the line work?
Detail Set-up - callout or duplicate...
Mon, Feb 6, 2012 at 9:24:54 AM
duplicate construction section with detailing error
Fri, Jun 24, 2005 at 5:21:58 PM
Callout: Detail view vs. Building section RAC 2008
Mon, Sep 24, 2007 at 2:05:38 PM
Callout/ Section/ Elevation marks on parallel plans
Wed, Feb 22, 2006 at 5:56:30 PM
Duplicate views create duplicate callout tags in referring views...
Fri, Mar 9, 2012 at 1:37:25 PM
Page generation time: 1.3259
