66 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Add railing to existing stair
Wed, Sep 22, 2010 at 8:53:36 PM | Add railing to existing stair
leothelionator
Is it possible to add railing to an existing stair or ramp?  If I attempt to do so, the new railing will turn out flat, not sloped with the ramp or stair.  I've learned not to delete the automatic railing that comes with a newly created stair unless I'm absolutely sure I won't need it later because it is such a pain to redo the whole stair just to get the railing.
Wed, Sep 22, 2010 at 10:35:51 PM | Add railing to existing stair
Dynamite
Dynamite Avatar
4.5 Stars: 35 Votes
Its possible to add a railing to a stairs, if you delete te default railing. Click on the railing tool, draw your railiing line and click on the host button on the project browser and then click on your existing stair. It will automatically adjust to the slope or riser.
Thu, Sep 23, 2010 at 4:36:03 AM | Add railing to existing stair
4 Stars: 202 Votes
Just one thing "...click on the host button on the project browser..." NOT in Project Browser but on RIBBON (top menu/right)
Thu, Sep 23, 2010 at 9:40:45 AM | Add railing to existing stair
leothelionator
Thanks, that will save me a lot of time in the future.  I noticed that you need to be careful that the railing is not placed on the outer edge of the stair or it will not catch the slope.  It needs to be placed just inside of the stair just like new railing would be automatically placed.
Tue, Oct 29, 2013 at 7:49:39 PM | Add railing to existing stair
EggandDart
"It needs to be placed just inside of the stair just like new railing would be automatically placed."
That's true, but remember that you can offset the railing so that it appears outside of the stair.
Thanks for the help!
R
Railing at stair bottom!
Thu, Feb 28, 2008 at 10:57:33 AM
Curved stair and railing issue
Tue, Oct 4, 2016 at 1:32:22 PM
Railing Path Modification
Thu, Oct 20, 2016 at 11:27:38 AM
Railing wont host to stair created in design option
Mon, Oct 24, 2011 at 3:54:39 PM
Default stair railing
Thu, Aug 26, 2010 at 1:08:26 PM
Page generation time: 0.5985
