83 Users Online (82 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> EWWW...concrete stairs are ugly
Wed, Sep 22, 2010 at 3:24:24 PM | EWWW...concrete stairs are ugly
gregroberson
gregroberson Avatar
I may be way off base here, but here it goes:
Stairs are a system family, so I feel limited in what I am asking revit to do.  But I feel like Revit has the ability to do it.
1. Can I kane the tread and risers disappear in a monolithic stair.?
2. Can the undersid of the stair be filled solid?
Greg
Wed, Sep 22, 2010 at 3:44:07 PM | EWWW...concrete stairs are ugly
3.5 Stars: 395 Votes
You wrote : "...1. Can I kane the tread and risers disappear in a monolithic stair.?".... What???
and "...2. Can the undersid of the stair be filled solid?"... Again what?  <<< If I uderstand this, add an in-place family to fill theis solid.
Wed, Sep 22, 2010 at 3:48:55 PM | EWWW...concrete stairs are ugly
gregroberson
gregroberson Avatar
Sorry.
1.  Can I have...
I attached a .pdf file.  I used a modify cut profile to get the picture I wanted for filling in under the stair
Wed, Sep 22, 2010 at 4:00:39 PM | EWWW...concrete stairs are ugly
If this needs to be modeled, then add an inplace family under the stairs... concrete.... and in the section, use the linework tool to remove the line between the stairs and this family.
Otherwise, in thie section, just add a filled rgion to fill in this area.
Wed, Sep 22, 2010 at 4:06:38 PM | EWWW...concrete stairs are ugly
gregroberson
gregroberson Avatar
Simplicity...Thanks.
Greg
Thu, Sep 23, 2010 at 9:51:55 AM | EWWW...concrete stairs are ugly
gregroberson
gregroberson Avatar
AWESOME!!!!
 Linework tool worked perfectly.  So mush easier that I thought.  Now I even have rebar cover ( must be adjusted for tread and riser thicknesses).  Stile frickin awesome.
Thank You WWHub
Concrete Stairs with winder
Fri, May 30, 2014 at 7:27:58 AM
Creating concrete stairs from raised exterior slab
Sat, Oct 25, 2014 at 10:26:43 PM
Using in place models to create an existing concrete stairs
Wed, Sep 24, 2014 at 7:14:40 AM
Hand rails and Stairs
Wed, Nov 15, 2006 at 5:04:46 PM
Stairs by sketch breaking
Wed, Mar 12, 2014 at 8:42:58 AM
Page generation time: 5.2067
