30 Users Online (28 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> Title Block Images
Wed, Sep 22, 2010 at 2:47:19 PM | Title Block Images
mlennon
I'm having difficulties exporting my Revit title block to .dwg and being able to control the .jpeg in the references dialog box. I've created a title block in Revit and have inserted .jpeg images for logos. These are the steps I'm taking...
1. Export sheet from Revit to AutoCad 2007, selecting "all properties BY LAYER, no overrides"
2. Opening the file in AutoCad 2009, changing the imageframe to 1, then REGEN and some of the images are visible and all of the image frames are visible, some are not. In the XRefs box it lists all of the images created from Revit and where they're located but says "unferenced". I cannot reload them or anything.
3. I then cut and paste the linework and images to model space to be used as a block in someone elses drawings.
I can right click on the references and click attach to reinsert them and re-establish the path but how can i embed these images and get all of them to show up in my Cad file? Am I making my title block family wrong?
Thanks for any help!
Wed, Sep 22, 2010 at 3:15:46 PM | Title Block Images
You have to manage the image in CAD ... it will be a link.  The problem usually is that when you send the CAD file, you have to also sent the image file and the path in the CAD file needs to be changed so that it is a relative path.
Importing Arch. Title block with all info.
Mon, Mar 30, 2009 at 4:55:03 PM
Font on Title sheet absent from project Title Block
Thu, Sep 15, 2022 at 12:31:27 PM
Title Block Issue
Tue, Feb 16, 2016 at 3:52:28 PM
How to import my title block from AutoCAD?
Mon, Sep 10, 2007 at 4:25:44 PM
12
In the default Revit Templates i couldnt find revit title block
Fri, May 23, 2014 at 7:22:24 AM
Page generation time: 0.7266
