Forums >> Revit Building >> Technical Support >> Better to link or just use worksets for a large project?
53 Posts No Rating |
Revit 2011. What is the best way to setup a very large commercial project internally? I have a large commercial facility with different components (commercial - 50,000sf, 12 storey hotel, large convention, ancillary buildings etc.) which total one large complex. Although I have pretty solid Revit knowledge, I have not yet done a project of this scale; therefore I've never had to decide the best way to break out a model into workable portions. I will not really need to worry about linking up with other consultants; I'm mostly concerned with the easiest way to manage it internally. For file size and control, should I have a master file with 3 or 4 major building components linked in, each with their own workset structure?... or, should I just have everything modeled in one central file (ie no Revit links), and use worksets to turn components on and off to make the model workable. Any help is appreciated. Thanks.
from your project description I will definetly look at linking! there is no way you can manage this whole project in one file (unless you have super computers ) in the main site file, set up worksets for each linked Revit models. in the linked models be careful about how you set up worksets, if you don't really need them, don't create anymore than the default ones... got to go but hope I can write more later...
Just to add to what eldados said, think about grids and levels. In multi-building projects, each building needs their own grids and levels may vary building to building depending on site and structure. You really can't manage those issues well in one project. But this is where Revit is great because you can use file linking. Each project can link in the site model (seperate project) and as eldados said, linking each building into the site in worksets gives you the control you need. BTW, we like to have the shell in a seperate workset in each project so that we can control that in composite site models.
Thanks! Thats what I had in mind, but I wanted to double check before getting too far down the line.
Nested Link in nested link workset control? |
Fri, Feb 28, 2020 at 5:19:25 AM
cannot enable worksets |
Tue, Jan 23, 2018 at 11:00:19 AM
13
Working on Large Files |
Mon, Jul 9, 2012 at 4:11:11 PM
11
What's the difference between Unloading a Linked Revit File and Removing? |
Mon, Feb 27, 2017 at 1:57:45 PM
Groups & Worksets |
Sat, Dec 15, 2018 at 9:00:16 PM
Members: | 2098726 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
