94 Users Online (91 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Changing level height values while keeping building in place?
Tue, Sep 21, 2010 at 12:08:31 PM | Changing level height values while keeping building in place?
chowlowhammond
Is there a way to change the values of my level heights without actually moving the entire building?
Basically the entire building needs to move up 200mm...  But the project is 99% complete. Physically moving the building means a full day's work of adjusting all the 2D information...
Wed, Sep 22, 2010 at 12:46:45 AM | Changing level height values while keeping building in place?
eldados
eldados Avatar
4.5 Stars: 8 Votes
yes you can!
you will need to relocate your project, assuming you are on 2011, just go to to the manage tab--> position--> relocate project, (best to do it in an elevation view) move the project 200mm high.
next, you will need to make sure that your levels (as well as spot levels) are set to use Shared Levels, just select one of your levels, go to edit type and change the Elevation Base from Project to Share, this will update to show correct RL...
Integrator
KarelCAD
Wed, Feb 22, 2012 at 6:08:04 PM | Changing building height?
Maximiliano
How can i move the whole building from groundfloor upto level 1?Keeping the building intact. I have tried but i doesn't work.
Thu, Feb 23, 2012 at 7:59:10 AM | Changing level height values while keeping building in place?
Assuming nothing else is in the model, change the names of the levels, then relocate the project to put those levels at the correct elevation.
Thu, Feb 23, 2012 at 1:01:32 PM | Changing level height values while keeping building in place?
Maximiliano
No i have funitures etc.. in the model.
Thu, Feb 23, 2012 at 1:11:38 PM | Changing level height values while keeping building in place?
The problem is not furniture.  It is site and other buildings that might relate to your levels.  What I suggested is a good solution.  Did you try it?
You can move entities from level to level starting at the top if you are moving up but that doesn't work if you have 2D elements in plans.
Thu, Feb 23, 2012 at 2:01:19 PM | Changing level height values while keeping building in place?
Maximiliano
is not working.
Thu, Feb 23, 2012 at 2:23:39 PM | Changing level height values while keeping building in place?
Is not working <<< WHAT?  Renaming the levels?
Thu, Feb 23, 2012 at 2:45:26 PM | Changing level height values while keeping building in place?
Maximiliano
it doesn't move at all. The thing is i want to lift the building from the ground 6500cm. but if i change the levels names notthing change its al the same height and it doesn't move of the ground.
I have tried by elevations moving the levels the same story, the floor and walls move with it.
I'm not pro with revit so i'm little bit slow. I'm working with revit for a half years now. so  have patient please. It is a school project.
Thu, Feb 23, 2012 at 2:56:57 PM | Changing level height values while keeping building in place?
OK.... Your last post is a help.
Create an elevation view that has all model categories turned on plus the levels and is deep enough to include everything.
  • Window the entire building and make sure you have the levels as well.
  • Remove the site from the selection set.
  • Make sure nothing is pinned.
  • Move everything up the desired amount and you should be done.
Thu, Feb 23, 2012 at 3:22:21 PM | Changing level height values while keeping building in place?
#11
Maximiliano
thank you it works. thank you very much
Tue, Apr 23, 2013 at 8:58:07 AM | Changing level height values while keeping building in place?
#12
danezeq
i have the same problem
it wont let me move the selection upwards (nor down) it only let me move the project to both sides.
what should i do?
Tue, Apr 23, 2013 at 9:16:55 AM | Changing level height values while keeping building in place?
#13
Check for pinned levels.
Tue, Apr 23, 2013 at 9:51:08 AM | Changing level height values while keeping building in place?
#14
danezeq
Thank you of your answer :-)
i checked - no pinned levels
do i uppin by "UNPIN" button of the LOCK icons? (which i don't know what the're doying..)
Tue, Apr 23, 2013 at 9:54:22 AM | Changing level height values while keeping building in place?
#15
You are moving in an elevation view - correct?
You have all levels selected - correct?  IF NOT, then maybe a level is dimension locked to another level you are not moving.
You really need to tell us more about your process because this is really simple when done correctly.
Setting Window Head Height
Fri, Feb 24, 2017 at 12:16:50 AM
14
changing multiple level heights
Wed, Oct 31, 2012 at 9:54:12 AM
Changing Project Levels While Keeping Survey Point Levels
Wed, Dec 4, 2013 at 3:49:13 PM
Greyed out level and height options on family / group
Wed, Jan 6, 2016 at 1:06:25 PM
Level height change
Wed, Sep 28, 2011 at 2:10:59 PM
Page generation time: 1.5890
