40 Users Online (39 Members):
Forums >> Revit Building >> Tips & Tricks >> How to create a 2x6 wood stud
3 Posts No Rating |
Hi all, I am new to Revit and would like to know if anyone could explain how to create a vertical 2x6 wood member to use as a stud in my current project. I loaded structural members into my project but can only get them to go in as horizontal members such as beams and joists. Thanks
![itsmyalterego Avatar](user_avatar/109615.jpg)
Usually you wouldn't model studs in revit since you don't really show studs in construction documents. But you can load it from Structural/Columns/Dimension Lumber-Column.rfa into your project, and you'll find a 2x6 in there.
![dgcad Avatar](user_avatar/6183.jpg)
![3.5 Stars: 36 Votes](/images/stars_3.5.gif) |
Also you must model it as a 'column' or 'structural column' and it's object style is controlled in those same two categories. It is not considered 'Framing' in REVIT. Columns are not 'Framing' they are columns or structural columns. So, you can load them from the location mentioned above from the insert tab > 'Load familiy' or you can load it after starting the structural column tool. OR you can just drag and drop the family it in from windwos explorer. Then use 'structural column' tool to place it while paying attention to the top and bottom constraints.
Edited on: Tue, Sep 21, 2010 at 12:44:31 PM
![GRINHEART Avatar](user_avatar/111551.jpg)
![4 Stars: 5 Votes](/images/stars_4.gif) |
If you are a subscription member... I believe you can download the "wood framing" under subscription center.
"If you tell the truth, you don't have to remember anything" |
If you try out the 'Wall Framing Extension' from the Autodesk subscription center you may want to read this review.
Does anybody know if this extension has been updated or a newer version is out? I came across this thread and thought it might would be helpful sometimes. Thanks!
Hello ... google! http://apps.exchange.autodesk.com/RVT/en/Home
4 Posts No Rating |
You can also check out MWF for automating placement of wood studs: http://www.strucsoftsolutions.com/mwf-professional/
Wood Stud wall |
Thu, Feb 12, 2009 at 9:05:51 AM
Wood Stud Wall Cut Patterns |
Mon, Feb 29, 2016 at 7:36:50 AM
Displaying 2X6 wood frame walls in floor plan |
Tue, Feb 6, 2007 at 10:00:52 AM
Wood frame projects |
Mon, Nov 14, 2016 at 3:41:23 PM
Wood studs |
Mon, Mar 31, 2008 at 2:24:59 PM
Members: | 2022349 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
