61 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Elements Missing in Render Image
Mon, Sep 20, 2010 at 7:55:27 AM | Elements Missing in Render Image
jaycee
Just recently some parts of my render will go missing. (ie a wall, floor, ceiling) It is even happening in renders that i have previously generated before without any problem. It seems to happen when i duplicate an element and then change its material, then when I render, that element is gone. The element still appears in all other views, even 3d shaded views, just not the render. Any ideas?
Mon, Sep 20, 2010 at 4:54:04 PM | Elements Missing in Render Image
jaycee
Im using revit 2011
Tue, Sep 21, 2010 at 7:17:06 AM | Elements Missing in Render Image
Kronny
3 Stars: 2 Votes
Hi,
I also using revit 2011.
Thanks.
Air Ventilation  ||  Roof Ventilator || Air Ventilator  || Roof Ventilators
Mon, Sep 27, 2010 at 6:07:56 AM | Elements Missing in Render Image
Benji23
Hey jaycee, I have no idea, i have the same issue though and I am using 2011 as well.
Is your graphics card supported by 2011? do you get a window popping up when you run revit notifying you that some feature may not be supported?
 I hope some has overcome the problem and knows whats going on.
 thanks
Mon, Sep 27, 2010 at 7:21:18 AM | Elements Missing in Render Image
Benji23
hey,
I tried downloading the service pack from Autodesk for revit 2011 and it has seemed to fix the problem, as well as another issue i had where my internal lghts weren't appearing in the render.
below is the link where you can download the file from as well as the read me which lists the other issues/ glitches the servce pack has addressed   =)
thanks
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=14973244
Decal Image Missing
Thu, Jun 12, 2008 at 10:37:22 AM
render appereance images missing
Wed, May 11, 2016 at 3:12:18 AM
Revit Image appearance missing
Mon, Feb 22, 2016 at 11:08:36 PM
Revit 2010 custom materials - missing like to image map
Mon, Aug 3, 2009 at 8:00:58 PM
Missing objects in my render
Wed, Mar 2, 2011 at 9:34:45 AM
Page generation time: 2.8659
